Radio Head unit?
i just removed both my a/c and radio using a hanging folder's metal hanging bars...the collar slip-ins kept bending out of shape!
hey, i used to live in TO from 82-92, takining road trips to UW and still pop up to TO a couple of times a year. it gets really hot down here!
Both sites go to Mercedesshop and say server not found. Yes I can fabricate pretty well. A template or measurements is all that is needed. Thanks for the ideas.
their site is temporarily down for some reason.
try this first, just found it: http://www.crosslake.net/~dbipes/SLK/auxin/
here you go, attached is the template....i just used some cutters and cut the tips at about 45 degrees - be very careful with hanging folder metal hangers - THEY WILL MAKE SMALL CUTS IN YOUR FINGERS AND PALMS! wrap electrical tape or sand them down where you will be handling them most.
once radio's out then what? here is some info.... http://www.benzworld.org/forums/w210...bracket-5.html ...i posted some links at bottom of page, username 'rkbad'....
Anyway if you still want it. PM me with your email and I'll send it as an attachment.
UPDATE: I just tried to again and it only displayed the name of the file. Also, same with kbad's image. Maybe site is having some problems. I know it was slow this morning.
I made your removal tools using the bar from a Pendaflex hanging folder. I used a pair of aviation metal shears to cut the bar in half, then shape them generally like the attached photo. I took all of :05 minutes and worked perfectly.
Thanks for a great tip!
Boyd
