Another transmission problem
Old May 7, 2010 | 12:45 PM
gatonls's Avatar
97 E320, 04 C230K, 06 R500
My 320 is having transmission troubles so i thought maybe its best to get the Carsoft to read the codes. I have an OBD II scanner....but its not reading any problems. Changed the fluid and spring 10k miles ago and ran fine till last week when it started shifting hard in both 2nd and 3rd gear?? It wont do it all the time but, starting to get on my nerves and I know its not normal for it to be doing it. I have been going trough the site for similar problems but, cant seam to nail it down as of yet.
I need your help on this one
Old May 15, 2010 | 10:37 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
You need to scan for transmission codes; if I understand it correctly, the typical OBDII scanner will not do that.
Old May 17, 2010 | 09:14 AM
gatonls's Avatar
Yeah, I tried scanning with the OBDII......no luck..............Iv'e ordered a Carsoft scanner last week.....should be here any day now.
Old May 17, 2010 | 02:04 PM
jgananE320's Avatar
2002 E320
i had no problem using my OBDII scanner when i needed to pull cell codes. what brand do you have?
Old May 20, 2010 | 09:15 AM
gatonls's Avatar
I have the Actron OBDII autoscanner.............OBDII will not allow you to scan transmission codes.
