help
Old Jun 12, 2010 | 03:15 PM
mzjuicey's Avatar
e430
Talking help
i have a 1999 e430 about two day ago i go out to my car and put the key in the ignition and it wont turn i check the batt and the ones in the remote they are fine now the key pad dont lock or unlock the doors it lights up but nothing happens,and the key doesnt turn at all. can some one pleaz helllllllp me in advance thnks
Old Jun 12, 2010 | 06:16 PM
raymond g-'s Avatar
99 E320
trickle charge the car battery. while you're there, check the fluid level, take a specific
gravity reading, and if you know how, check the voltage under load. at the very least,
replenish fluid (distilled water), and then trickle charge overnight with 10 amp charger.
several days with 1 amp charger. you get the picture. report back
Old Jun 13, 2010 | 06:29 PM
mzjuicey's Avatar
e430
dont know how to check voltage under load and if theres any more suggestion let me know thanks
Old Jun 14, 2010 | 01:13 AM
raymond g-'s Avatar
99 E320
i hope you are understanding that unless you help eliminate one of the primary
causes of the symptoms you describe, you're just setting folks up for pure
speculation.
verify that the car battery is fresh and of sufficient capacity to start the car
and support the appliances and we can go from there.
quite a bit of the time, people come here and say 'i checked the battery and
it's fine' but that, at face value, is an opinion and not a diagnostic description
of how such a conclusion has been verified.
so how was battery health verified for both car's primary battery, as well as
the Smartkey battery?
(skip the load test and at least proceed with the others suggested)
Old Jun 14, 2010 | 09:50 AM
saintz's Avatar
GL450
If you go to Autozone or similar store they can test your battery for you, normally free of charge.
Old Jun 14, 2010 | 11:34 AM
TMAllison's Avatar
09' E320
Turn key to pos 2, press and hold REST on CCU for 5 sec, use L/R AUTO buttons and toggle to screen 24.
If batt voltage is less than ~11.0-11.5V its not going to crank.....If less than 12V re-read what Raymond said.
Old Jun 14, 2010 | 12:17 PM
raymond g-'s Avatar
99 E320
wowzer - forgot about that one, tnx. i usually pop the hood and just pull out
the fluke meter. but when on the road, this can be very useful.
Old Jun 15, 2010 | 11:50 AM
TMAllison's Avatar
09' E320
Also fun to watch screen 6(?) on a hot day with the AC on in slow-n-go traffic and see the dead spot on the dash temp gauge between 95-105C. The gauge holds 95C until it hits 105C, then instantly jumps. Was done to cut down on needless shop visits. CCU reports accurate coolant temp always.
Old Sep 2, 2010 | 11:29 AM
mzjuicey's Avatar
e430
sorry havent been on here in a while but i to had buy a new key which cost me $242.00 but it fine now
