Long Cranking before Engine Starts
#51
Welcome Darren,
Are you referring to your 2004 clk w209?
You are in the wrong forum. This the w210 forum.
w209 =============> https://mbworld.org/forums/clk55-amg...-w208-w209-45/
#52
Thanks for your concern. Fuel gauge didn't solve my problem. I took a bet and changed the fuel pump and fuel filter again and everything is good again. The fuel pump that I changed in 1 year earlier is for E350 up and not for mine which is E240. The parts guy had the wrong part delivered to my old mechanic who probably didn't check before getting it installed on my car. The fuel pump before this might also be wrong - that makes me not to the suspect the fuel pump again, until 5 months ago when I really exhausted changing parts.
so I have the exact same issue as you, I have changed fuel, pump, fuel filter, cam shaft sensor, crank shaft sensor, MAF sensor, spark plugs, Coil packs, all original parts, no check engine light, battery is only a year old, and the car runs great once started. I’m tired of throwing money into it.
