HELP PLEASE
Old Jun 23, 2010 | 09:18 PM
kinghais's Avatar
1999 W210 E300 Turbodiesel
HELP PLEASE
Hi guys, i just got a 96 E300 Diesel and i have some problems with it
i hope u guys know.
The ABS and ETC light comes on sometimes when im driving is that mean i gotta change my brakes or something??????
the Climate Control acting funny, driver side got no AC and but the passenger side works fine. i checks all the fuses , wut can it be?????
i can't drive w/o AC
Help please
Old Jun 23, 2010 | 10:25 PM
TexFinn's Avatar
10 Tahoe LT, 07 Silverado Z71, 99 BMW R1100RT
AC issue sounds like a problem with duovalve. The ABS/ETC light could be the brake light switch. There is a different light for brakes needing replacement.
Do a search and you'll find lots of good info on both.
Old Jun 24, 2010 | 12:08 AM
raymond g-'s Avatar
99 E320
i can't drive w/o ACHelp please
try this, then get back with diagnostic results
Old Jun 24, 2010 | 06:00 PM
kinghais's Avatar
thanks guys
Old Jun 25, 2010 | 04:48 PM
moayes's Avatar
ML350 2010 AWD
Addition
This might be helpful too:
http://www.benzworld.org/forums/w210...uble-code.html
Old Jun 25, 2010 | 06:29 PM
TMAllison's Avatar
09' E320
While you are driving around with Raymonds CCU diagnostic screens running, also pay attention to screen 24 too. Low voltage can cause both ABS and ETC to light up.
Old Jun 26, 2010 | 12:40 AM
kinghais's Avatar
i can't really read the codes cause the right side has bad pixel
Old Jun 26, 2010 | 12:43 AM
LawRens's Avatar
43
ooh, you're SOL then, arent you? lol
you COULD swap out the unit for a working one if you have a spare?
Old Jun 26, 2010 | 12:49 AM
kinghais's Avatar
i guess lol. . . i'm thinking to buy one.
I hear Loud hissing when i turn on the ac and then i turn it off. wut can it be? leaking?????
Old Jun 26, 2010 | 11:23 AM
TMAllison's Avatar
09' E320
Hissing noises from the center vent, and warmer air on the left than right is oftentimes indicitive of a system that is low on freon.
Old Jun 26, 2010 | 10:41 PM
kinghais's Avatar
i checked the freon and it was low but not too low and filled it up, but still samething
Old Jun 27, 2010 | 02:30 AM
kinghais's Avatar
does anybody know where is brake light switch located ?
Old Jun 27, 2010 | 08:44 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Behind the brake pedal.
Old Jun 27, 2010 | 09:44 AM
saintz's Avatar
GL450
If you search on here you'll find instructions for replacing the brake light. You drop the panel under the steering wheel and it snaps in and out.
Old Jul 4, 2010 | 12:00 PM
armaniE55's Avatar
2012 CLS63 AMG
If you still need help with the brake pedal switch I wrote a DIY/Pics
GL
Armani
https://mbworld.org/forums/e-class-w...s-bas-esp.html
Old Jul 7, 2010 | 01:51 AM
kinghais's Avatar
that worked, Great ! thanks guys
Old Jul 20, 2010 | 02:43 AM
kinghais's Avatar
help please i changed the Brake light switch, but the ETC and ABS light comes on again, it comes on whenever i use e-brake when i park, i stopped using e-brake when i park, and it doesn't come on. anybody had this problem????
