E220 Flashing Indicator Relay Unit
Old Apr 11, 2003 | 05:00 AM
john.clarke's Avatar
Question E220 Flashing Indicator Relay Unit
Hi all..........Have E220 Sportline ((W210) ......Natal S. Africa
I would appreciate info on the flashing indicator relay unit.
On indicating left or right the centre of the three relays buzzes, yet the emergency flashers work OK. Neither of outside two relays call at any time.
No hot or burned components.
I am electronics guy, so need circuit diagram or pointers of circuit M.O.
Notes of an old thread....
..........If any-one of the chaps involved is interested....my viscous fan bees wax mod is still performing well with the climate temp. falling to below 15 deg.
.......thanks for any help........TYKE
Old May 5, 2003 | 09:05 AM
Hi all.........Managed to get a cct diag. .......very unusual source of problem...........guess what........Fuse 6.......not blown......just bad connection, could not take the intermitant load.
The flashing hazard light utilisation of the indicator lamps is routed via Fuse 9, which was why the same lamp worked OK in the Hazard function.
.........Tyke
