4k rev limit in drive
Old Jul 26, 2010 | 04:42 PM
wali_r's Avatar
E55
My 1998 has a engine speed problem. When driving, rev limiter keeps the rpm from going past 4k. This is supposed to happen only in P or N. Dealer said MAF voltage is out of range and needs replacement. Replaced it, no change. no fault codes either. The ECU was replaced. I bought a used one and had it unlocked and reprogrammed for this car. Anyone experience this before? I am thinking there may be something with the gear indicator. Maybe the ECU thinks the car is in P still. Any thoughts?
Old Jul 26, 2010 | 05:03 PM
saintz's Avatar
GL450
Throttle Position Sensor? Is the car really slow and lags between pushing the pedal and accelerating? Does your cruise control work?
Old Jul 26, 2010 | 05:20 PM
wali_r's Avatar
E55
Car responds fine. Good power, no hesitation, until you hit 4k rpm. Then the car chokes. Once the rpm goes below 4k, runs fine again.
