synthetic oil longevity ???
2005 E320 4matic wagon
Mobil 1 has an oil out there advertised as good for 15K miles. This goes against the traditional rule of 5-6K for normal syn oils. Any one had experience,good or bad, with this? Would like to use this oil if it is truly safe for that many miles.
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
It all depends. On operating temperatures, how long at that temperature, operating conditions, engine condition, etc.
I use the FSS on mine.
I did a lot of work in the old days using oil sampling to determine oil change intervals on OTR truck engines and City engines. OTR could get 25,000-35,000 easy using regular old dino Rotella and a centrifugal bypass oil filter. City trucks would get about 7,000 set up the same way. Big difference based on operating conditions.
Some don't trust FSS. I do, based on my experience. Since I am on the road alot (214,000 miles so far on this one), my interval is about 13,000 to 15,000 miles. I use Gold Cap M1 5-30, from WalMart at 27 bucks per 5 quart jug.
So is that company going to buy you a new engine in 30k miles when you have only changed their oil twice? Hell no! Use good judgement. Moving parts at high temps need clean oil. I change my fully synthetic oil in my M3 every 4 or 5k at most no matter what they say... at the end of the day, its your *** when that engine stops running right.
What a silly argument. You have taken the oil change mantra of 30 years ago and lived with it. Keep justifying your expense.
Read my post. 214,000 miles using FSS. No knocks, noise, no smoke, 27mpg on the highway.
I guess no engines that had their oil changed every 3000 miles ever blew up, correct? They run forever. And if they did blow up, the lubricant manufacturer gladly bought the consumer a brand new engine. What a dumb argument.
That's not the argument. I don't remember ever saying the words "blow up" anywhere. Simple really. Who's going to pay when the engine stops working? Good you have q car that's made it 214k miles. God only knows what kind of build up is lurking in the engine. That's like the real smart people that said tranny fluid was life time! Did those company's buy people new tranny's at 150k when they failed? No. Do what you want. Just how I see it.
I've had the valve covers off at 200,000. Like new.
If you drive in town and never get the oil up to operating temperature for any length of time, yup, you should change every 4000 or so. I also believe FSS would indicate that.
You omnibus change-the-oil-every-4000-miles mantra - XOM, BP, etal, luv ya man.
And how many engines have you rebuilt, designed, machined, etc?
Rebuilt - 7 why does that matter? Should we see who's is bigger next? Like I said do what you want. Unless You or this oil company is buying the OP a new engine when and if I goes I wouldn't tell people that its fine to wait 15k to change oil with out asking a lot more questions. Like how he/she drives the car? Or how many miles are on it now? What type or oil have you been using? Have any leaks? Like I said to each his own.
Read my first reply. Read the first sentance. WE AGREE! Jeezuz.
WHY are YOU bent on 5000 miles? I'm not.
I am saying - it depends. If you have FSS, trust it. If you don't, then some decisions need to be made. One is simply thow your money away. Another would be to study the situtation and make an educated decision.
90% highway miles, minimum 1 hour at a time - 13,000 should be no problem.
Trips to the neighborhood grocery store, once a week, no warm up time, better do it in a year, which may only be 300 miles.
ps - Mine are bigger than yours.
GL450
+1
Trust the FSS. It tracks how you drive and adjusts based on that.
Look at it this way... the company selling you the oil tells you the oil will last for 15k miles. If it really only lasted 5k, why would they tell you 15k and sell 3 times less oil?
Mercedes is very particular about what oils you can and can't use, and even they say (based on the FSS programming) that you can do over 10k miles on the oil.
I would recommend to only use Mobil 1 0w40 (or another approved oil). Although 5w30 seems "close," and it is in terms of viscosity at different temperatures, the additive packages and formulation are totally different. There is a reason that 0w40 is generally not sold anymore at discount stores like Walmart and is rarely available in 5 quart jugs. It's better oil than 5w30 or any other weight, and it's generally only sold in the full price, single quart containers. Advance Auto sometimes runs 5 quarts for $30: stock up on the good stuff.
2001 E320
I live in Florida, and I was told not to use 0w40, case its too (thin or thick, cant remember the term). I have 01 E320 with 106K miles, and I live in the SUPER hot state Florida, should I still use 0w40?
2008 ML350 4matic
0W40 is fine for Florida, it protects from -50 F to +400 F....my mid west dealer has just switched to 5w40 by the facotry recommendations. The 5w40 will give you more "heat" protection, for peace of mind. Just make sure you dont you use the ESP 5W40....that's for a diesel.
I'm sticking with 0W40 every 10k...
GL450
This is a quote off Mobil's website regarding the Mobil 1 0W40:
0W40 is basically magical oil. When it's cold, it flows like water (the 0W means it's very low viscosity when cold). When it's hot, it sticks like glue (40 means it is high viscosity when hot). 5W30 is inferior oil: in cold conditions, it's thicker and gums up more, and in hot conditions, it's thinner and doesn't coat as well. This is one reason that 0W40 is recommended, and also why it's harder and generally more expensive to find compared to any of the other, inferior weight oils. The other reason is that 0W40 has a better additive package (detergents, friction modifiers, etc.).
Bear in mind that your engine runs at between 80 and 100 degrees Celsius, which is around 180 to 210 degrees Fahrenheit. In FL (or where I live in SC) it's maybe 100F. So your engine, after warming for about 5 minutes, is running at twice the temperature of the atmosphere, meaning your oil is way hotter than the air around you. In other words, the climate you live in is generally irrelevant to your oil choice.
The exception is with regard to cold starts. If you live somewhere cold, you need a low winter weight (like 0W or 5W). If you live somewhere warm, you don't (a 10W might work). But 0W40 is magical oil. It starts in Alaska (0W winter weight). It runs well in a hot engine in a hot climate (40 weight).
If your oil was an umbrella, 0W40 is a golf umbrella. It has you fully covered, from cold starts to hot operating temps. 10w30 is a pocket umbrella. It's not as good when it's cold, and it also doesn't lubricate as well when your engine is at operating temperature.
Originally Posted by http://www.mobiloil.com/usa-english/motoroil/oils/mobil_1_0w-40.aspx
providing the extreme cold start protection of an 0W grade and the high temperature protection of an SAE 40 grade.
GL450
Originally Posted by http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Using_5W-40_Motor_Oil_in_Mercedes-Benz.aspx
Question:
Using 5W-40 Grade Motor Oil Instead of 0W-40 in a Mercedes-Benz
I've been using Mobil 1 0W-40 synthetic oil in my 1992 500E Mercedes for 4 years now and have been told to consider 5W-40 grade for my car. I live in southern California, my mechanic only carries 0W-40 weight, and I want to ask if the 5W-40 grade is better then 0W-40 grade all around?
-- Steve Vainshtein, Los Angeles, CA
Answer:
Both a 5W-40 and 0W-40 will provide the same level of protection at high temperatures, especially if you are using a product like Mobil 1. As far as the 0W versus the 5W, this should not make a difference for you other than at start-up. The 0W would provide you a faster start-up at low temperature but you are unlikely to see the differences in your climate. Either grade is fine for you and unless you are having any issues, we recommend you stay with Mobil 1 0W-40 as it is specifically designed for your type of vehicle
Answer:
GL450
Regarding the additive package, which is the other main difference between oil weights, here's the chart from Mobil: http://www.mobil.com/USA-English/Mot...duct_Guide.pdf
Note that 0W40 has more Phosphorous and Zinc added compared to most other oils they make. In other words, even if you live in a warm climate and can get away with running 10W40 instead of 0W40, it has a different additive package and won't provide the same longevity and protection.
Jiffy Lube is quite pleased the 'every 3000 miles' mantra is still floating around.
My FSS would approach 15k when I drove almost exclusively long-distance highway. Now that I rarely use the car, and for local short trips,it has shortened considerably.
2001 E320
"saintz" you also mentioned about oil temperature runs at "80 and 100 degrees Celsius". When i look at my oil temp gauge, it always show its at 88-90. (not when its cold starts of course). after i drive a mile or so, it climbs to the 90 mark. Even though 80 is the middle of the gauge. Thats normal? (bear in mind, i'm in Florida)
2003 S210 3.8L Brabus wagon
GL450
1 Post
His mama. Traded y0 mama in because she was squeaking.
100 degrees is nothing on a pressurized cooling system.
Typical coolant won't boil until about 120C in a typical car's cooling system. The good stuff won't boil until 375F (190C), and even that, a 0 PSI. That means you can leave your expansion tank cap off, and the good stuff won't even notice it's not there, and still only boil at 375F. Of course, long before the good stuff starts boiling, your engine oil will be toast.
