quick question about tps (throttle position sensor)
Old Aug 4, 2010 | 06:24 PM
zheka's Avatar
2001 E320
Question quick question about tps (throttle position sensor)
i bouth TPS (throttle position sensor) today, and i'm gona change it tommorrow, and I just wanted to know if I have to do anything special before or after I swap it out.
Old Aug 7, 2010 | 07:40 PM
saintz's Avatar
GL450
After you replace it, turn the car to On but don't start it. Push the throttle slowly all the way to the floor (make sure you engage the kickdown switch). Release. That is supposed to calibrate it.
Old Aug 9, 2010 | 12:55 AM
zheka's Avatar
2001 E320
ooops... i already put it on, without calibrating. I dont see any problems it had with it... Should I still re-calibrate?
Old Aug 13, 2010 | 01:43 AM
saintz's Avatar
GL450
I guess, yes, but I'm not sure it matters. If it works right, you should be good.
Old Aug 13, 2010 | 10:27 AM
zheka's Avatar
2001 E320
ye it works perfect. it doenst throw me in limp mode anymore when i floor it
