Will not crank
Old Nov 11, 2010 | 07:27 PM
John H's Avatar
14 E550, 07 E550, 69 Mach I, 65 Hipo, 66 Fairlane GTA Conv, 66 Fairlane GT
Will not crank
My 2001 w210 will not crank. Battery appears OK and all other electircal systems work. All fuses look OK and I swapped all like-kind relays.
The starter got stuck yesterday and kept cranking after the engine started. I shut the engine off and restarted. All was fine. Went to restart later and not it will not crank.
My first thought was that it was a starter solenoid issue. Not being able to replace just the solenoid, I replaced the starter. Yes, I should have bench tested the starter but ..... Engine still will not crank.
Anyone have a suggestion how to proceed?
Old Nov 11, 2010 | 08:35 PM
Fabio D's Avatar
210 55
K40 Relay in the control module box (passenger side under the engine bay) remove the 4 screws & you will see a little black box with some fuses, wires & one black relay, change the relay by a new one
Fabio Daniel
Old Nov 12, 2010 | 01:55 PM
John H's Avatar
Fabio
You were dead lugnuts on! Mucho Thanks.
When I pulled the back cover off of the K40 relay it was obvious where a component had failed and fried the circuit board.
The part number is A 000 540 00 72 and was in stock at MB with a retail price of $111.63. BTW this appears to be the part number for most/all W210s. It took all of 10 minutes to replace.
Here's a pic of the bad part. Note the copper section which got hot, burned off the green top layer, lifted off the board, and finally melted the copper in half.
Old Nov 12, 2010 | 08:02 PM
Fabio D's Avatar
210 55
hope it help you bro! let me know any news
at your order my friend!
PD: Bro i see some white sulfite marks in the green board, check the proper fitment of the box module cover to not entered any water.. hot modules without proper closed box produce some evaporation & appers this marks burning relays, modules, etc. check too inside the EGS module if you not have any trans oil inside, some cases oil inside the EGS burns the relay box
Fabio Daniel
Old Nov 14, 2010 | 01:21 PM
John H's Avatar
Yeah, I saw the sulfate(?) stains too and thought it might be from water intrusion but when I looked at the bottom of the plastic cover there were no water stains or deposits.
Thanks again!
Old Nov 14, 2010 | 02:58 PM
Fabio D's Avatar
210 55
All good my friend
Fabio Daniel
Old Nov 17, 2010 | 11:11 AM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
I have a similar situation. After a long drive and have the car shut off, and when I tried to start it back on 15 minutes later, there's this long crank and the car will not start. My tech told me it's the Crankshaft Position Sensor. So could my case be the relay too?
Old Nov 17, 2010 | 08:11 PM
01BlackE320's Avatar
01 E320
Nope because your car is cranking. The relay problem is this thread prevents the car from cranking. The Crankshaft position sensor will prevent the engine from starting. Common problem on the w210 and on Chrysler Jeep vehicles
Old Nov 17, 2010 | 09:55 PM
Fabio D's Avatar
210 55
1+
Crank + no start = Position sensor or fuel pump (most common)
No crank, no start, no nothing = Battery, relay, starter (most common)
Fabio Daniel
Old Apr 12, 2022 | 02:34 PM
Kledian Prela's Avatar
Mercedes Benz w211
Fabio Daniel
I have the same issue, car will
not crank and the K40 relay looks good
Battery is im good conditions
