Advice on installing a cd player
Old Jan 6, 2011 | 11:37 AM
RandyYLin's Avatar
E430 2000
Hello I wanted to know whether or not I should have this installed into my 2000 E430? The car has a bose system installed too.
Pioneer DEH-2200UB CD Receiver with iPod Direct Control and USB Input.
http://www.amazon.com/Pioneer-DEH-22...4329903&sr=1-1
Any ideas where can I find a cd player wire harness for this car? What are the shortcomings of proceeding with the installation (heard some issues with bose system)? Or should I just return the cd player back to amazon and save myself some hassles?
Thank you
Old Jan 6, 2011 | 11:49 AM
kbad's Avatar
2001 E320 - RIP
hey Randy.... the pioneer deck is a good choice, however the 2200 will not drive the stock bose amp unless you also pick up a line driver (i.e. bose amp is looking for 4V input and the 2200 can only deliver 2V) .... i'd suggest either getting a scoche oe4 adjustable line driver ~$30 or return the 2200 and pick up the 6200BT, it'll give you 2 or 4V and bluetooth to boot! .... the harness you will need is the Metra <link rel="File-List" href="file:///C:%5CUsers%5CKaya%5CAppData%5CLocal%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:ApplyBreakingRules/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:UseFELayout/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Font Definitions */ @font-face {font-family:SimSun; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-alt:宋体; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 680460288 22 0 262145 0;} @font-face {font-family:"\@SimSun"; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 680460288 22 0 262145 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:SimSun;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshowes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]-->#70-1784 for VW ... also pick up a straight antenna adapter, since the mb antenna connector is angled and will not go deep enough to make contact! .... good luck!
Old Jan 6, 2011 | 12:07 PM
RandyYLin's Avatar
E430 2000
Thank you Kbad! I'll head over to my mechanic to view your insight. Will post back sometime later on the results. Thanks again
