2008 E to 2001 E Tires & Rims
Old Jan 11, 2011 | 07:04 PM
rquarle's Avatar
2001 MB E430 4Matic
Thumbs down 2008 E to 2001 E Tires & Rims
A newbie here! I own a 2001 E430 4-Matic. The previous owner installed 18” rims with low profile tires that look good, ride hard and wear out fast! I am looking to put more rubber on the road and make my car ride as a Benz should without spending a lot of money.
I have found a set of nice 16” rims and tires from a 2008 E350. The tires are 225/55.
I know bolt pattern is the same but does anyone know if these will these fit my car without modification?
Thanks for your help!
Old Jan 12, 2011 | 02:47 AM
andy the hun's Avatar
Zaporozec heavily modded 36HP
check the off set "ET" stamped on the back side
should fit between 32 and 41 mm
Old Jan 12, 2011 | 10:04 AM
raymond g-'s Avatar
99 E320
proceed carefully, and be aware that the newer rims will no doubt require a
larger bolt lug. they have 14mm bolt diameter as well as larger ball seat than
the 210's 12mm diam and ball seat specifications.
there are bolt lug manufacturers which make 12mm diameter bolts with 14mm
ball seats (RADUSADIRECT and OTISINCLA)
Old Jan 12, 2011 | 11:29 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
If they are wearing out fast was the car lowered? Sounds like it might have been and then not used the adjustable rear camber arms. Newer wheels require larger ball seat. Must get custom lugs as stated above. ET 35 is ideal for stock W210
Old Jan 13, 2011 | 01:23 AM
Theropode 430T's Avatar
S210.270 & W201.018
You need al least 17" rims, 16" wont fit because of the brake!
