transmission or engine issue..help me...
Old Jan 30, 2011 | 04:13 AM
ndepbo's Avatar
e 420
The short version.. bought a 97 e420, in 09, haven't had fluid change, it drove good but I couldtell it needs a tune up. It started taking awhile to shift so I drove it manually, now it moves slow and when it runs, I hear a noise from the passenger side every now and then. How can I change the transmission fluid?
Old Jan 30, 2011 | 08:52 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
you should have the 722.6 transmission, which was new for the W210. it is electronically controlled, compared to the old er722.4, which was hydraulic only and used Dexron II or III ATF. read this:
http://www.benzworld.org/forums/w210...ml#post3647154
Old Jan 30, 2011 | 09:24 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
The link given will provide the procedure.
However, you might want to start by having the transmission scanned for trouble codes by the dealer.
Old Feb 2, 2011 | 08:38 AM
bad hare's Avatar
audi/porsche
^ great resource. those guys are a bunch of stiffs though. get what you need and get out. dont even register.
