High beam not working...
Old Feb 23, 2011 | 05:34 PM
joekluger's Avatar
e430
Question High beam not working...
anybody know where the high beam realy would be on a 2001 e-430? or any other ideas why the high beam would not go on...thanks
Old Feb 23, 2011 | 06:11 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Have you checked the fuse with a tester? Ext. lighting fuses are in panel at end of dash. Separate fuse for each high beam.
Old Feb 24, 2011 | 12:34 PM
joekluger's Avatar
e430
Red face
not the fuse cus it worked once in while. then it high beam would go on when i put the right blinker on and now it will not go on at all. thinking it must be a switch or relay....thanks
Old Feb 24, 2011 | 01:00 PM
RichardM98's Avatar
Or maybe a problem with multi-switch on steering shaft?
Old Feb 24, 2011 | 01:01 PM
joekluger's Avatar
e430
sounds like a good possibilty. how do you get to it so i can test it?
Old Feb 24, 2011 | 02:54 PM
juve010's Avatar
e320 4matic wagon
I had a problem with my high beams. My 01 had a bad combo switch. The blinkers/wipers worked fine, just the high beam function was shot. Pretty simple diy. remove air bag, remove steering wheel, remove switch...reinstall. I think there is a diy tutorial on this site or maybe benzworld.
