Vibration - Engine mounts or Flex disc
Old Mar 5, 2011 | 06:52 PM
TO_MB's Avatar
2011 e350 Wagon & 2004 e320
Well fellaz, I bought a 98' e430 past December and has approximately 255,000 kilometers. Previous owner said mounts would have to be changed down the road and was fine with it. But since drivingm, vibration was getting worse. did the least expensive first, rebalancing tires, etc and still there. Sometimes I feel a vibration on the steering or front but definitely have vibration on my @ss and rear passengers feel it too.
Did engine mount test and it failed, parts are on order. Im just thinnking... is it possible the vibration on the seats could be caused by the flex disc? from my search, vibration on the seats most likely comes from the rear. I just want this vibration to go away
Thanks for any input and/or advice....
Old Mar 5, 2011 | 11:22 PM
saintz's Avatar
GL450
Vibration in the rear definitely sounds like flex disc. There are two, one front and one rear.
Bad engine mounts will cause rough idle and acceleration hurts from the flexing.
Flex disc will cause vibration if you gas it and then let off and let it coast, in particular.
Old Mar 6, 2011 | 12:00 AM
TO_MB's Avatar
Thanks, I think I will just replace both mounts and rear flex disc and see if the vibration goes away..... Just trying to distinguish where the vibrations be on those old/worn/torn parts.
Old Mar 6, 2011 | 01:55 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If one disc is due it would be a good idea to replace both at the same time. You have a lot of miles and years on those.
Old Mar 7, 2011 | 08:32 PM
01BlackE320's Avatar
01 E320
try to find out where the problem is coming from and replace those parts. No sense in replacing the flex disk if it's fine
Old Mar 7, 2011 | 08:58 PM
TO_MB's Avatar
I'll do the engine mounts first and see. It needs to be replaced anyways. If same vibration is there, then will change the flex disc. thanks fellaz...
Old Mar 8, 2011 | 12:58 PM
Musikmann's Avatar
Sounds like a plan.
Old Mar 17, 2011 | 06:55 AM
TO_MB's Avatar
Got the parts in last night and will attempt the job today. Wish me luck.....
Old Mar 17, 2011 | 11:32 AM
cbpeck's Avatar
2000 E 320 4Matic Wagon & 1993 Toyota Camry
Just curious,
How severe of a vibration are we talking about? My wagon vibrates some at highway speeds, but I've assumed that it is just the way the 4Matic system & stiff suspension respond to rough NW roads. I haven't driven anybody else's W210, so I don't have much to compare it to... other than a '93 Camry with 210k.
Old Mar 19, 2011 | 10:47 PM
TO_MB's Avatar
Finally got the mounts changed! Had trouble with top mounts due to the angle. But with a little patience finally got to turn a little which was all I needed to loosen it up! Driver side mount was shot, its the one on the right in the pic below with the new one in the middle! On to the flex disc tonight.
After changing the engine and tranny mounts, did notice it run a lot smoother but vibration on the seat still there.......
Old Mar 19, 2011 | 10:50 PM
TO_MB's Avatar
cbpeck, not quite sure exactly on the vibration from the mounts other than at idle and stops. Mine in particular is on the seat on your @ss which leads me to believe something in the rear. Almost feel like the wheels in the back are oval. Really noticeable around 40 mph but eases off a bit at 60 or so. Had to replace my mounts anyways as you can see from the pic.....
Old Mar 20, 2011 | 03:50 PM
live_evil626's Avatar
96' E320 W210
Did you drive the car in between changing the mounts and the flex disks? I recently changed my mounts including the trans mount. I noticed the flex disks were in need of changing as well. Their was such an improvement already, i'm trying to gauge how much doing the disks will be?
Old Jun 13, 2011 | 07:51 AM
smackleboom's Avatar
1999 E 320
seems like no one has yet conquered this problem. I have the exact problem (99 E320 Base) I have read many posts that sugest throwing parts ( in most cases needed changing) but none the less problem still exist. its definately between the driveline (drive shaft system) and rear wheel bearings drawback for me is that I live in the islands dealership prices are trippled
Old Jun 15, 2011 | 02:36 AM
zr-1's Avatar
92 mercedes benz 500E,91 corvette ZR-1,90 mercedes benz 300CE AMG body pkg.
is the driveshaft balanced on these cars , i owned a fleet of rigs and sometimes you would lose a welded on weight on the driveshaft which can cause a vibration....just a thought .
adam
