Wondering if you still have these available? Looking for the 5K city lights. Also wondering if you carry any of the LED lights for the fogs.. I currently drive a W210 E55 AMG.
Yes these are still available. You can purchase these through our website www.aznoptics.com. As for fogs, you'll really want whiter halogen bulbs or a full hid kit. LED doesn't look good in halogen reflectors. You end up with tons of light scatter and zero throw distance.
I have to replace the running lamps on my 1998 E320 with the stock H6 clearance lamps. I have the factory xenon. I notice you've talked a lot about reflectors and throw, which I appreciate a lot since so many people just fit new HID bulbs to stock reflectors like people. My question is, should I be concerned installing the LED clearance lamps? Not that they do anything anyways, but should I be concerned about road glare and such?
ditty,
the H6 bulb serves to add glow as opposed to driving illumination of the road. as
such there is no realistic concern about 'throw' or projected glare. they are only
5-6 watts and the lumens is correspondingly low.
I've used both H6, H5, as well as currently the LED module and the bulb simply
identifies the front end of the car to opposing drivers. the bulbs glow dimly at best.
Generally speaking, and forward throwing light, you don't want to use LEDs. LEDs are ideal indication type lighting and not illumination type lighting. They can't properly utilize halogen reflectors. New plasma LEDs are a bit better, but 3D LEDs could potentially work, however technology isn't there yet where we'd confidently carry and recommend to our customers.
I love the look. Do you have any LED headlight bulbs? Also in the silver E Class pictured below. What are the fog lights? I'm trying to change all of my bulbs. Thank you
We do have H7 Plasma LED kit for your low beams.... that said, I'd personally recommend against any LED swap for any primary forward projecting light in housing not designed to properly capture LED light spread. You will end up with reduced throw distance and light scatter. HIDs are a better solution and we do have HID kits for your application.
Your fogs use H1 bulbs which we currently do not stock, but can special order from Morimoto as their direct distributor and H1 HID kit.
Just ordered for my e320. I bought some for my w203 a while back and they worked flawlessly. One of my lights went out so I knew it was time to upgrade to these. Any chance there is still the % off if I post pics when I install them?
Looking for some city lights and possibly fogs for a 210 e55 in a 5k temp. Will the fogs throw an error code or are they plug and play?please PM me with your response.
Awesome how much for a ful HID set of bulbs for the high and low beams. I just want the brightest bulbs possible for my high and low beams, my turn signals, license plate light and all of my rear lights. What do you recommend. How much would I be looking at spending.
I'm assuming you have OEM halogens for your low beams. For you to go HID, it won't be just a set of HID bulbs, but you'll need a full HID conversion kit. Both your high and low use H7. We're direct distributors of Morimoto HID kits and their XB35 Elite HID kit will run $150/kit. This is a full plug and play system that will include everything you need.
As for the rest of your bulbs, we can swap those for LED variants. Your front and rear signals use a set of 1156 bayonet IC LEDs which retail $30/set. Rear plate uses a set of 36mm festoon LEDs which retail $20/set. Reverse lights use a set of 1156 bayonet LEDs $30/set. Front city lights use a set of our H6W mini-bayonet LEDs $20/set. Front sidemarkers use a set of 194 wedge LEDs which retail $20/set.
Depending on how much of what you buy, we can probably work out a forum discount. Just shoot us a PM and we can put together an invoice for you
AZN Optics is now offering next generation Morimoto XB35 HID conversion kits. Available for order on our site www.aznoptics.com or PM us for more details.
Could you send me an I nvoice quote for everything you listed above, and the shipping cost to Napa, Ca.
As you said above this is a plug and play, so no cutting wires or splicing etc. and the process should take less than 30 mins for all lights?
