retrofit: headlamp washer
I want to retrofit headlamp washers for my 98 E430 Mercedes. I have the trim molding and the headlamp washers already. I have the switch in the dash. Does someone have the wiring harness or the parts number for the wiring harness that runs from the headlamp washer, to the fuse box, to the switch in the dash? If so please let me know. Thanks in advance.
You can look up the part number(s) here: http://epc.startekinfo.com
Be nice if you had WIS document AN82.15-P-0001-01A, "Retrofitting headlamp cleaning system wiring harness."
You can likely find it by subscribing for a day at http://www.startekinfo.com
Does anyone have instructions for installing the wiring harness for the headlamp washer to the fuse box and dashboard switch? If you have any diagrams and pictures, they will help also. Thank you in advance for your assistance.
