Turn Signal/ High Beam Light
I've also looked in the stickies... Pls H.E.L.P....thanks
My turn signals are NOT working (got a ticket on it yesterday), the Hazzord flasher works though.
High Beam doesn't come on when the combo switch is pushed towards the engine, but will come in if hold towards the driver.
What do I need to replace to correct this???
is it the multifunction switch OR the turn signal relay/module inside the engine.
please let me know what I need to get and the best place to get it from..thanks!
Any help will be appreciated.
thanks
I was told that the '96 model don't have the turn signal relay...but that is not the problem with my car, the 97 and later has the relay.
My mechanic said the problem is the high beam switch (module), which is located under the dash.
when you wiggle it to one side the high beam works and when you wiggle it to the other side the turn signal works.
he's going to change the module tomorrow and I hope to be smiling by tomorrow evening...I'll keep you updated...
i have a c250 1997 and its starting to do the same . flashers /windows/ horn/heated rear window and mirror adjustment. when it stops working i pull the battery and give it a few mins and then it works again on reconection. any idea,s guys.
