1996 E300D radiator support
I went through a similar situation with a 1987 E300D, but I can't remember if new struts solved the problem. The '96 appears to have shocks instead of struts, so I don't know if renewing them is a potentially a solution.
The fan blades will cut the core/tank joint from the support moving so far up and inward, which either indicates poor engineering (unprotected sheet metal support) or a faulty something.
Anyone have a suggestion for a cure?
The radiator support is protected by the bumper and a shield under the bumper covering the front end. I suggest removing the front bumper. You won't be able to see anything without taking the bumper off...
Here's a picture of the of the lower support with the three "fingers at the top edge being the area for welding to the frame.
I'll have to straighten the radiator support and reweld it, but I'll just use a repaired radiator until I determine if I've solved the problem.
I hit a hole on the street and the radiator was pushed into the fan that put a hole into the radiator.
Now I have to replace the radiator. yucks!
The lower radiator support was also straightened and screwed back to the frame where the spot welds had broken. So, it saved me from having to buy another $200 radiator.
