E320 Starts but then it doesnt, Help?
Old Jun 11, 2011 | 05:26 PM
gonzaga707's Avatar
E320
Smile E320 Starts but then it doesnt, Help?
I have a 1997 E320 and i had it stored for 3 months without starting it, afther those 3 months I turned it on and it worked fine, then I left it there for 2 more months until the battery died. I got a new battery and now the car is having problems. It will start fine the first time, but if i turn it off i have to wait 10 minutes for it to start again. I took it to a mechanic but he said he couldnt pin point the problem, he said it might be a relay and if he changes it, it will need a new computer. Anyone had the same problem? any Help? Tips?
thank you for reading. what kind of relay might he be talking about,
thank you.
Old Jun 14, 2011 | 10:13 AM
illest's Avatar
w210 AMG or S213
when you try to start it without waiting 10 minutes what happens?
Old Jun 14, 2011 | 11:16 AM
Thierry82's Avatar
ML320 1999
@gonzaga707, in regards to what a relay is, the mechanic is referring to the switches that transfer power from the energy source in your vehicle to the component that needs to perform it's task. Basically, when you turn the key switch in your car a multitude of relays switch on to connect power to your ignition, fuel pump and many accessories.
If you do need to switch out an accessory in your car, I'd suggest going to this site www.programainc.com.
I've dealt with them before. Their repair time and delivery is exceptional!
