Banjo bolt fuel line
Anyway, when the car sits for only a few hours, I see this line (#7 below) clear (no fuel), so I'm assuming air is getting in.
So just a basic question -- is it important that the little hole in the bolt line up with the fuel line itself? I'm assuming so. I can look into tightening it up, but I am concerned I would lose the alignment if that's needed.
The new connectors are otherwise nice and tight, so am curious how I'd get air in there. I'm considering changing my fuel filter, 'cause that's easy, though I don't think that's a candidate for air intrusion.
Thanks!
Chuck
Yes, it turns over fine. That one was the only o-ring I didn't change out. I guess what I don't quite understand about the whole banjo bolt thing: I actually see the little hole in the main bolt, so I am wondering if it needs to somehow line up with the fuel line that comes off of the ring that goes around the bolt. Or maybe it doesn't matter?
To work with this particular line I have to remove the manifold so unfortunately "playing and testing" is kind of a labor intensive thing!
Thanks,
Chuck
