Rear Window
1 Post
2014 E350 4matic, 2015 Acura TLX
Thanks, I was hoping for something that didn't require taking the whole door apart though. If there's something easier, I'll give it a try but otherwise, no big deal because nobody can sit behind me anyway.
'99 E430, '05 ML500, '15 GLK350
Does neither switch work? Check the fuses (2 and 18 I think). You may also try disconnecting the car battery for 2 minutes to reset the control units on the CAN bus. Don't forget your radio code first.
1 Post
The left rear is the only one that doesn't work - doesn't make a freakin' sound. Your suggestion(s) sound more within my mechanical abilities. I'll give it a shot and see what happens. If it doesn't do the trick, I'll probably just leave it. I'm 6'4" and nobody can sit back there anyway.
