CHEAP 12 VOLT OIL EXTRACTOR FOR OIL DIY CHANGE
Old Aug 20, 2011 | 06:04 PM
dwnsouf7's Avatar
01 E320
$35.99 @ BASS PRO SHOPS
  • Saves you time and money
  • Completely self-contained
  • Includes battery clips with 8' leads
  • Magneteized bottom
Drains 5 quarts in 3 minutes!
This 12-volt Oil Changer pumps oil out through the dipstick tube without mess, saving you time and money. Completely self-contained 12-volt electric rotary pump has the extra power to drain oil from larger vehicles. Includes battery clips with eight foot leads, one large and one small pick-up tube, and discharge hose. Battery clamp cord stores in unit's tough molded case. Magnetized bottom holds the unit to steel
JUST FYI IN CASE ANYONE IS DOING THE DIY OIL CHANGE WITH OUT LIFTING THE CAR THIS LITTLE MACHINE PUMPS OUT REAL FAST , THEN WHEN FINISHED YOU CAN REMOVE THE FILTER AND VOILA" ALL CAN BE DONE IN UNDER 40 MINS OR LESS
HERES A VIDEO LINK TO A VERY SIMALR MACHINE DOIN THE JOB. QUICLY AND CLEANLY OVER THE TOP
<iframe src="http://www.youtube.com/embed/MtUZHT99owo" allowfullscreen="" frameborder="0" height="345" width="420"></iframe>
Old Sep 1, 2011 | 03:37 PM
CerBErusM113's Avatar
2015 CLS63 S AMG
Awesome find! Cant wait to get one myself
Old Sep 18, 2011 | 11:58 AM
dwnsouf7's Avatar
01 E320
YEA ITS ALSO PERFECT FOR ACCIDENTLY OVER FILLS, SOMETIMES YOU MIGHT OVER FILL THE ENGINE OR TRANSMISSION WITHOUT KNOWING JUST BY WHERE U PARK...DEPENDING WHERE U PARK U MIGHT OVERFILL ALOT AND CANT EVEN TELL...
