A/C Question
Old Oct 9, 2011 | 09:35 PM
E320User's Avatar
Black 2000 E320 4Matic
A/C Question
I took it to a mechanic to check and he said that the A/C on my left side only cools to 16 degrees Celsius while the right side cools all the way down to 6 degrees Celsius when I put it on the Low setting. He said if I wanted to know more he'd have to charge money, so I decided to come here and see if anyone knew what the problem might be so I could hopefully perform a DIY
Thanks ahead!
Old Oct 10, 2011 | 12:48 AM
E320User's Avatar
These are the codes I got
Part 1 Collect Sensor data
1-21
2-18
3-42
4-40
5-16
6-58
7-04
8-18
Part 2 Trouble codes
Left Right
eb1 231
eb1 235
eb1 416
eb1 424
e ff
e
Old Oct 10, 2011 | 12:18 PM
Palermo Len's Avatar
1999 Mercedes E320 Wagon & 1927 Bugatti Kit Car
My "99 Wagon has that problem every few years and I just add some freon (or whatever it called now) and that corrects the problem.
Old Oct 21, 2011 | 01:44 PM
kbad's Avatar
2001 E320 - RIP
hey man....the sensor data seems normal, you may want to run the individual flap test, could be the left side flaps are not opening all the way! i'm attaching a pdf file (with full credit to Steve Brotherton and Blake Cameron).... addressing the trouble codes should be your first step, specifically replacing the bad/faulty sensors...good luck!
Old Jul 13, 2013 | 12:51 PM
carter2012's Avatar
mercedes
NEED HELP !
I JUST BAUGHT A 2000 MERCEDES S500 AND 2 DAYS AFTER THE CAR DIED ON ME I WENT TO SEE IF IT WAS THE BATTERY BUT THEY JUST BAUGHTTHE BATTERY ON 03/13 FROM THE MERCEDES DELERSHIP SO THE SAID IT WAS MY ALERNATOR SO CHANGED THAT AND AGAIN MY CAR IS COMPLETEY DEAD I NEED HELP ASAP
