EC stuck on.
Old Oct 9, 2011 | 11:02 PM
The Scurge's Avatar
1997 E420
EC stuck on.
My 1997 E420 EC button is on. I had the R134a checked and it is at 90%. What could cause this?
Old Oct 11, 2011 | 10:09 PM
raymond g-'s Avatar
99 E320
run the on-board diagnostics first and log the readouts. the EC/light is a protection
device which prevents burnout of the system. so don't try to fix the light. fix
the cause of the light staying on.
Old Oct 12, 2011 | 01:07 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
+1
Also, you might check for error codes B1233 and/or B1234 which are for the refrigerant temp/pressure sensor. Early model sensors were prone to moisture contamination causing the EC light to come one. A sensor with a better design was made available as a replacement.
Old Oct 12, 2011 | 11:17 AM
The Scurge's Avatar
1997 E420
Thanks for answering. I took it to a local importshop. The system has two very slow leaks. One in the compressor and the other one is at the low pressure port.
Old Oct 19, 2011 | 02:21 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
OK so the light is on indicating the compressor is off (protection as mentioned). Fix the leaks, evacuate and refill the system and the problem is solved.
