HU cannot detect CD changer (original parts)
Old Oct 27, 2011 | 12:35 AM
blue960's Avatar
W210 - V6'02 / W163 - V6'02
Question HU cannot detect CD changer (original parts)
need advice .... my original HU suddenly cannot detect the CD changer (also original) ... tried ejecting CD casing out and then insert it again .. tried ON/OFF couple of time ... still the message : no CD .. what happen ya? optical cable?
Old Oct 27, 2011 | 01:33 AM
raymond g-'s Avatar
99 E320
sadly, this is a common 210 ailment with the CD changers, which, I opine, are
horribly designed and will (will) continue to exhibit problems. the only thing I
can think of is to try a reboot, that is, disconnecting battery and allow electrics
and electronics to wake up again after reconnecting.
i've read where it may sometimes take a few mins of power down, to even an
overnight down time.
BE SURE you have your radio code on hand, otherwise you won't be able to
unlock the head unit after reboot. this is part of the anti-theft feature.
Old Oct 27, 2011 | 10:14 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
You might also want to read this post on CD problems and solutions.
http://www.benzworld.org/forums/w210...air-guide.html
I think the best solution for music is to install a AUX-IN cable on the radio and use an MP3 player.
Old Oct 31, 2011 | 12:25 AM
kbad's Avatar
2001 E320 - RIP
hey man... take a look here.... https://mbworld.org/forums/e-class-w...-question.html ... i've posted a diagnosis that you can try to see where your problem might be.... good luck!
Old Nov 6, 2011 | 10:29 AM
blue960's Avatar
thank you guys... i disconnected and reconnected the battery...voila..the HU now recognizes the changer again.. hopefully it wont happen again ..crossing the fingers
Old Nov 6, 2011 | 04:16 PM
RichardM98's Avatar
Next time (likely) try disconnecting the D2B (optical) cable. Should have the same effect without the resync hassles.
