license plate bulb replacement
how to change the license plate bulb on 2000 e430 what is the center a clip / or what , thank you
99 Mercedes E320 Sedan
to change the bulbs for the license plate i removed the inside liner to the trunk lid. using a flat screw driver to pry the little pin tab thingies. then after you remove it, you should be able to just reach in and you should be able to change them. hope that answers your question.
