Mystery Oil Leak
Old Nov 6, 2011 | 06:31 PM
n_roorda's Avatar
1999 E430
Mystery Oil Leak
pulled the 430 out today and i notice a small bit of oil on the garage floor. JAW DROPS and now my football sunday is ruined by curiosity and anger! Prior to me noticing this engine bay has always been clean along with the under carriage.
Car has not been driven in about a week, looked inside engine bay and notice oil on the bottom sitting on the plastic floor board thingy (sorry, dont know what it is) Engine bay is still clean besides the bottom portion. Undercarriage now has some oil spray from when i drove it today.
Is it possible to just get an oil leak overnight from a car that is just sitting?
I thought maybe from when i chnaged the tires and lifted the car it somehow twisted the car/engine?? (wild idea but im so confused)
Old Sep 29, 2012 | 05:42 PM
olixandru's Avatar
oil problem
If you have a worn gasket may flow there may be engine oil or gearbox
Old Sep 30, 2012 | 08:40 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
The most common oil leaks are from the vent covers on the valve covers, and form the little oil pressure test port on the front driver's side of the engine. Both easy re-seals.
Have you had your oil changed recently? Sometimes the wrong o-ring on the filter cap is used, causing a leak down the filter housing.
