PLZ HELP ME
Old Nov 22, 2011 | 05:15 AM
ra7et's Avatar
e320 1996
PLZ HELP ME
I have a big problem is not identified on the cause
( my car w210 e320 1996 )
When you run the car happens next
1- Heat index of the machine does not work
2-Index is always full of gasoline
3-There is no water in the radiator
4-There is no water spaces
5-External temperature sensor does not work
Other things work
Video illustrates the problem
http://www.youtube.com/watch?v=rosL-...ature=youtu.be
Old Feb 16, 2012 | 01:35 PM
ra7et's Avatar
e320 1996
Plazzzzzzzzzzzzzzzzzzzzz
Old Feb 16, 2012 | 08:27 PM
illest's Avatar
w210 AMG or S213
try disconnecting the battery and the sensors might reset and work properly. If there is no water in the radiator that is the first thing you need to take care of.
Old Feb 16, 2012 | 10:03 PM
CKonstantin's Avatar
W210 E300D
I believe what he means is that the cluster is saying there's no water in the radiator.
There's another thread on the issue
https://mbworld.org/forums/e-class-w...ng-gauges.html
Although its slightly different, I believe none of the people affected found a solution yet.
Checking the fuses however would not hurt.
Old Feb 24, 2012 | 06:24 AM
ra7et's Avatar
e320 1996
Please select from Let the unit responsible for meter
Old Feb 24, 2012 | 06:10 PM
W210 E300D
There is none, it's integrated into the cluster, K-40 Relay would be the one on the far right with the fuses in it. K-40 is worth looking into as a preventative measure anyway, Google K-40 fix and you'll see what the usual problems with it are.
