Transmission fluid leak after Replacing CV axle
I am 99% positive that I snapped the circlip in all the way to the transmission when I put the new CV axle in. Is there a seal/ O ring or something that could have gone bad or fallen off that I didn't notice?
What should I do?
Thanks,
2002 E320 4matic
150,000 miles
The indy wont touch it again, and its looking like i may have to take it in To the Dealership if i cant find a solution.
Any help is Very greatly appreciated,and thank you in advance. 1999 E320 4Matic 128,000 miles
-Anthony.
If the leak is coming from the transfer case shaft seal, I can appreciate that Seattle Sam won't touch the car----loads of special tools/time for a 8 dollar part, plus you have to know what you are doing!!!
How and where did you have it finally repaired? And how much did you end up paying for the fix?
As for in your case,Idk what a shop by you would charge for labor, but I asked then what his going rate would have been,& he told me for that job $75 flat. So,just check around and see, & good luck!
