When Cold Start, the engine is reving 0-1300rmp
I need a little help..
There was a MAF problem with my car: bad smelly smoke,lot of fuel usage..
I replaced it with a new one, not Bosch but work perfectly.No smelly smoke,normal fuel usage.
But, when i did this it was 10celsius..Now more likely to -5celsius.
When i start the engine a problem comes out,engine revving,and yes Sometimes fall down to 0RMP and back again to 1300,and 0,and 1300,and after a while,if the engine not stop, everything is alright.
But when i push the accerlator pedal a bit to fix the rmp to 1500 for a minute,everything is ok.
When i change gear when the engine is cold, P to R the engine stop sometimes..
Very strange to me..
Please somebody help
Thank u guys!!
Fabio Daniel
After when we did this procedure, we delete all problem with STAR DIAGNOSTIC, there was 5 Big F( i think failure) and 3 small f. After when we delete all these,just the xenon automatic leveler system was the failure, little f. i know this problem(xenon)
The MAF sensor before delete was big F, and after when we delete it, not comes again.
i think this could change the battery take off method.
new symptom: When i go with 50km/h my leg on the accerlator pedal, not thortling,just stay on them and keep the 50km/h speed, and the cars RMP still jumping and the car is shakeing.
good quality, my shop told me that. But i have now a bad feeling about this shop...
Easy way: Disconnect negative baterry for 12H+, after, connect the star diagnosos tool and simply reset all the fault codes (remember to initialize the steering angle sensor lock to lock and normalize all your windows/roof
Hope that help
Fabio Daniel
and i think now its getting better...So maybe the lot of city driving,the egr getting carbonized cause the lot of smoke..What will i do: i will clean the EGR valve,with brake cleaner spray, after WD40 to lubricate it,I will do this 12h+method,change the plugs,and wires,and maybe replace the outer temperature sensor.
