Radio DOA and no climate light.
Also, a couple of months ago, the lighted display on the climate control unit didn't light up. I gently tapped it and it came on. But it got progressively worse and now won't come on at all. The climate control system works fine, thankfully. Just no lights. Again any suggestions would be appreciated. Thanks.
The radio could have just failed. If you getting power to the radio you should see a display. A radio shop which specializes in MB (or German) car radios can hook up a known good radio to check the car's wiring harness. If that's the case then you have to decide what to do about repair/replacement. Becker NA will do an exchange for the same radio if you are interested.
As for the climate control unit light being out, the light has probably gone out or became loose. There is special keys that MB dealerships have to pop it open you can go there and they will pop it open for you for free or there is keys you can buy or make if you search the forums for it, mine went out before and I took it to my dealer and they just popped it out and put in new bulbs and it was working good as new.
Good luck!
If I have to take it to a shop that specialises in German audio systems, I might be in trouble there. I don't know of any shop like that in the area. But I will inquire at some A/V outlets to see if anyone can help. Thanks for the suggestions.
