What do I need to look for in a 98 E430?
Old Jun 27, 2003 | 06:49 PM
Matt_NH's Avatar
C320 Coupe
Thinking about picking up a used E for the wife.
What are the known issues with the V8 and the car?
Thanks,
Matt
Old Jun 27, 2003 | 09:58 PM
aglasgow's Avatar
1997 E420 Sport
definitely not a complete list but I'd check the following:
A/C - make sure it was routinely serviced. it's a known problem and a costly one.
Transmission - if the car has over 50-60K, it should have had the transmission fluid/filter changed. although MB says it's fluid for life, almost every mechanic I know says it should be changed. this is also a regular problem (transmission probs at high miles)
engine oil leaks
oil change interval - if it's a 98+, is has the FSS system which indicates oil changes at every 10K miles. this is also a point of debate but there were lawsuits going around due to this. Ideally, you'd like to find an E where the oil was changed more regularly (always synthetic).
dashboard cracks
driver/passenger seat noise "clicks" when steering/shifting weight
front coil spring/strut cap support - there was a TSB on this. improper sealing caused some to rust through.
There are probably more problems that can be considered somewhat systematic, however, they are great cars. If the one you are looking at has complete and regular maintenance records, you're probably ok. I would also invest the small dollars for a pre purchase mechanical inspection from a Mercedes certified tech.
Good Luck!
Old Jun 28, 2003 | 06:51 PM
Randy B's Avatar
**SOLD***2003 E500
Also make sure you run all the windows up and down a few times as well ast the moon roof. Many a faulty window regulator can be detected simply by making the window work a few times when it has not been in a while.
