Hard pull at 65+ mph
Old Mar 4, 2012 | 11:02 AM
Kayos77's Avatar
2012 ML63 with P30 package
Last month I went on a road trip and decided I should align the car just to be sure everything was in tip-top shape. All the specs were right on with each other and just had to set front toe make the steering wheel straight. In the city the car drove great, on the highway, well, I have to hold on for dear life or else the car will make a right hand turn for me. Thought it could be an abnormal tire issue so I had the tires rotated side to side. Still pulled hard. (tires in question are continental dws 235-45-17). Took those tires off and put on some brand new nitto snow tires for winter. Car drives great on the snows and no pull........at least that's what I thought. Took friends to the airport last nite and the pull came back. It's not as bad at it was, but I still have to hold the steering wheel around the 10 o'clock position to keep it straight.
Old Mar 4, 2012 | 11:54 AM
Brau0318's Avatar
Mars Red 2005 C230k, 2001 E320 4matic
Tie rods and bushings? I'm just throwing that out there for them to look at. Otherwise I would go back and say a little louder so they understand. ALIGN, ALL FOUR WHEELS, FRONT AND REAR TOES. Then they should be doing a road test themselves to check there work. I'm having a hard time believing that tires would act like that in the blink of an eye. Unless they had a pretty good wear pattern that you didn't notice from not getting rotations and wheel balances. Ignored long enuff and that could happen but there maybe more going on here.
I have had bad tires before, I dont know if it was a bad tire or poor air pressure mointoring. I was driving down the road and all the sudden my car felt like it was limping along the road but it had nothing to do with my engine or drive tran. I had a giant bubble on the side wall of a low pro tire . It looked like a tumor. That was werid shtuff
Old Mar 4, 2012 | 12:17 PM
Kayos77's Avatar
Being a tech myself (Acura) I did the alignment myself at work and adjusted the toes accordingly. None of the tires are worn abnormally. Tie rod ends are tight and the bushings appear to be fine. I don't do much highway driving so it's not a huge concern right now, but I would like to get it fixed before my road trip to Dallas
Old Mar 4, 2012 | 12:42 PM
Brau0318's Avatar
Front suspension pass visual? Front right wheel bearing not turning like butter, causes friction and acts like a stuck brake pad, pulling the car right. At slower speeds it had more weight on it, forcing it to work properly. You pick up speed and the bearing has less pressure/weight. Cause the problem to jam up easier, via less force on it to spin.
I have no clue, im sorry, I'm just throwing out ideas.
Old Mar 4, 2012 | 04:16 PM
track_warrior's Avatar
Like The Stig
Weird man, my car is rock solid at high speeds. Must be a crappy alignment.
Old Mar 4, 2012 | 10:08 PM
Kayos77's Avatar
I hope the alignments I do aren't crappy
Old Mar 4, 2012 | 11:31 PM
Brau0318's Avatar
Yeah I dont think he read the whole thread. If so, good day to you sir
Old Mar 5, 2012 | 02:12 AM
Like The Stig
Did you check every bolt, one could have come loose thats what happened to my c63 steering felt weird every time there was an uneven surface. MB dealer replaced all bolts since they did the alignment.
