Broken Sway Bar Mount
Old Jun 30, 2003 | 12:55 PM
bigtire's Avatar
96 E 320 and 87 560 SL
I recently noticed a bad rattling noise from the front of my 96 E320. Upon investigation I found the passenger side sway bar mount had failed. The nut mounted on the frame just pulled right out of the frame. There looked to be a little crack that had caused some corrosion. I welded it back together, but now I don't have much confidence in the rest of the mounts. Has anyone else had a similar problem?
