1999 E320 trans in limp mode after being replaced
Old Apr 22, 2012 | 12:55 PM
RoRo315's Avatar
1999 E320
I had my transmission replaced and it won't shift out of first gear, I've been told several times to replace the conductor plate, I also read on here that replacing the battery could be a fix also. I guess I need to have a Star scan and go from there...any suggestions as to what's going on? The car sat for 6 months before the trans was replaced, the battery was tested as bad, but I hooked it back up, and the car started. So let me know what you guys think.
Old Apr 22, 2012 | 02:07 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If there are error codes stored in the transmission control unit you have to have those cleared. Any dealer can do this or some of the larger independent shops. I don't think you need a battery because if it is too low the car will not even crank.
