Oil level at minimum warning at 85C
Old May 10, 2012 | 03:30 PM
TommyBBBoy's Avatar
W210 E290 Turbodiesel
Some time ago I got Oil level at minimum warning 2 or 3 times so I decided to replace oil level sender along with engine oil and filters.
But about 1 month after the sender was replaced I started to get warnings about low oil level everyday while driving to work, I noticed that warning is showing while engine coolant temperature hits about 85C (when I turn off and then turn on engine the warning is not showing again).
Oil level on dipstick is about 2/3 when I check it after night.
Old May 21, 2012 | 05:28 PM
Brau0318's Avatar
Mars Red 2005 C230k, 2001 E320 4matic
Oil sensor dirty/bad or like me you have started burning oil at an alarming rate. I throw 2 quarts about every 2,000miles. So i'm constantly getting thoose warnings. Thats the extent of my knowledge on the issue, never had to dig too far into it.
