Radiator
Old May 22, 2012 | 08:09 PM
earld's Avatar
2001 E430, 1999 SLK230
Radiator
I forgot to mention also. The radiator has been leaking a while also and I want to change it . Do I need a radiator with or without the oil cooler? 2001 E430 Thanks
Old May 23, 2012 | 01:25 PM
earld's Avatar
radiator
Old May 23, 2012 | 02:06 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Do you mean the cooler for the transmission fluid? If so, I believe you do.
Old May 23, 2012 | 02:37 PM
earld's Avatar
Yes I just call all those coolers oil coolers. The way I learned what they were when I was growing up was oil cooler.Regardless of what they cooled. Are they called Transmission oil coolers ?
Old May 23, 2012 | 04:40 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
I believe the cooler is integrated with the radiator. The fluid lines screw into it.
Old May 24, 2012 | 09:22 AM
earld's Avatar
I found an OEM rad. The company listed a radiator without the cooler. When I saw that I thought straight drive. I didnt think Benz made an E430 with standard transmission. So, I thought I would check with you experts (because I am far from that when it comes to the Benz) about what to do. Sorry to confuse everyone . But I think I got it now. Thanks
Old May 24, 2012 | 02:23 PM
Musikmann's Avatar
Correct, there were no E430s imported to the USA (for sale as new cars from the dealers) with manual transmissions.
