Need help to fix AC in my 99 E320
Old Jun 3, 2012 | 08:18 PM
zdzich's Avatar
1999 E320
Found no leaks. The AC compressor turns on for about 15 seconds and then goes off. Checked the pressure in the system with engine running and climate control turned on for the lowest temp. Low side has about 100 psi and the high side about the same. Any ideas ? I will appreciate your feedback.
Old Jun 6, 2012 | 01:30 PM
PelicanParts.com's Avatar
SPONSOR
Answer
These links should help you.
http://www.peachparts.com/shopforum/...l-how-use.html
http://www.peachparts.com/shopforum/...e-control.html
http://www.peachparts.com/shopforum/...-vehicles.html
roy@peachparts.com
Old Jun 6, 2012 | 04:47 PM
zdzich's Avatar
1999 E320
Thank you, I will check all the links you sent me.
