E320 Transmission issues
So what I experienced are 2 issues and both issues seem to manifest when cold:
1. It only happened once to me once, it stuck into second gear and would not upshift. I pulled into a parking lot, put it in reverse, then back on D, problem gone.
2. What is happening with increasing frequency now, but still not all the time, is that when it upshifts, sometimes, it will "kick" quite violently, like there is no vacuum. This also happened a couple of times as the tranny shifted down, but mostly on the upshifts.
Now the scary part is that when its doing that, it almost stalls the engine so, you accelerate normally then bang it happens, the car stops accelerating, engine almost dies and then its up and goes again. That can be dangerous in the traffic so I'm very concerned at this point.
It seems that when the tranny is in operating temp, there is no issue.
Please help and thank you.
I NEED HELP TO SOLVE MY FOLLOWING PROBLEM FOR MY 1997 E-320 CAR.
RECENTLY I WAS LESINING ON MY TAPE WITH ENGINE SHUT OFF, ALL OF A SUDDEN IT STOPS. I STARTED THE ENGINE BUT FIND THE FOLLOWING PROBLEMS:-
1.I CANNOT CHANGE THE RADIO STATION.
2.MY WINDOW IS NOT WORKING.
3.WHEN PUT IN DRIVE, IT GOES WITH A JERK.
4.GEAR IS NOT SHIFTING FROM 1ST GEAR.
5.RADIO AND WINDOW WORKS FINE WHEN THE ENGINE SHUT-OFF.
I TOOK IT TO MY MECHANIC AND HE SAID IT IS VALVE BODY PROBLEM AND NEED REPLACEMENT. MY DOUBT IS, HOW VALVE BODY FAIL WHEN ENGINE IS SHUT AND HOW IT IS RELATED TO WINDOW AND RADIO OPERATION. I THINK THERE IS SOME ELECTRIC PROBLEM.
ANY BODY CAN HELP PLEASE.
KARTIK
SROJBNRJ@HOTMAIL.COM
Cheers
Took the car to my local wrench who mainly repairs/maintains W210's so plenty of experience there. I asked him to do a tranny fluid change to which he agreed that it could the the culprit for all the issues I faced.
Having read that MB fluid should be used, I asked him about it and he swears by "wolf's head" synthetic fluid on all Mercs. I was a bit apprehensive, but I trust him due to his experience.
So fluid changed, new filter and gasket. It was obvious that the fluid in there was past its expiry date and it was also quite low. On the pan there was very fine particles, but with the current mileage it was expected.
So fluid changed, he warmed up the car, rowed through all gears and at op temp he checked and toped up the fluid.
Off I went then, first impression was that on 2nd gear downshift to a stop i had a hard kickdown constantly. Not as hard as it used to be on occasion, but noticeable non the less and kind of concerning as it was obvious that the only thing changed from before was the fluid.
Drove the car for 100K that day and the next day my wife took it to work. I told her about the hard downshift and asked her to keep an eye on it and let me know. Apparently it did not do it on her way back from work at all. She drove the car for the past week and yesterday I drove it as well.
I must say that now its smooth, no hard kickdowns, smooth upshifts, really really nice. All and all i think the issue now is dead and I'm quite surprised really at the results of a simple fluid change...
Like everyone says, just do it every 60K or so
I checked the DTC today and found P0560,System voltage malfunction. Pluto was suspecting the voltage before, thanks for your guess. What is the next thing I should do? Should I replace the battery, though it show 12.2 volt?
I checked all the fuse, all are fine. I tried to erase the code but it is not erasing, means the fault remains there. Now I plan to replace the main battery first. So, please guide me the procedure to change the main battery and reset the computer after change.
Thanks.
How many miles on the car, and how many years on the battery?
This is the recent update.
I replace the battery with MAXX-H6. The DTC P0560 was earesed and there was no DTC but the operation problem like no gear shifting and no operation of radio and window when engine running is still there. When I put back the old battery the DTC P0560 came back.
Anybody can help me?
