Oil dripping/running under radiator
Old Jul 2, 2012 | 07:06 PM
rodfletcher's Avatar
e 320, clk500
1998 E320 Avantgarde Auto (Petrol)
Hi Guys,
I have just noticed an oil leak, quite significant and centrally from beneath the radiator area.
I unclipped the fan cowl and can just see a solid pipe about 10mm diameter, fastened centrally below the radiator on a crossmember. The leak is at this central fixing point.
Can anyone confirm what this pipe is? could it be transmission fluid, perhaps a power steering cooling line
The oil appears clean and clear
Regards
Rod
England
Old Jul 3, 2012 | 02:32 PM
e 320, clk500
Oil leak
Hi
Thanks dor the peply
Car is RHT
Its petrol
Does it have an in/out auto tran cooler
Power steering pump is on the left passenger side
Rod
