newbie with a heater headache.please help
http://www.ebay.co.uk/itm/1808644219...ht_2547wt_1110
ive installed it as per the great diy thread on here about it.switched it on and low and behold it blew at full power,i thought great job done.then a minute later it slowly slowed down to a wisper again.i found that leaving it on low speed for a while will allow me to turn it upto max but only for short periods before it slows down to a wisper again.have i bought a cheapy regulator as it seems to kind of be overheating.btw i had to cut some heatsink pins off the motor to fit the regulator as the new one was bigger than the old.i also crimped the existing loom to the new regulator harness,would that make any difference?.one final thing,it came with some paste which i applied to the bottom of the regulator before i screwed it to the motor,is this right or does the regulator get bolted down dry?
please please help as i feel its better but know its not right
What I would suggest(if the motor is fine, and this it the correct regulator for your car), disconnect the wiring from the regulator and send it back to the seller for a replacement, if you leave the wiring on they will most likely say that your tempering with the wires caused the problem.
If you are successful at obtaining a replacement, be very careful when removing its wiring to replace with the modified one, as those Chinese regulators are quite flimsy. Also double check all your splices. Soldering is the preferred method but if cannot do it that way, I would recommend sourcing some insulated terminal blocks from a hardware store overlap the two wires and screw it tight, make sure to insulate it properly.
If all fails get a quality replacement unit from a reputable online store.
regards the regulator i had an early style little black box which had a loom attached to it.part number 9140010281.i had to splice as the loom on the new regulator seemed too short.as it worked better with the new regulator i would say its a dodgy chinese one that i purchased.you think they would replace it with the chopped wiring and can you recommend a decent company to obtain one from here in the uk or a company that will deliver to the uk without high import fees?
I can't assist you with picking a supplier, cause I'm from the other side of the pond, perhaps someone else would chime in.
.ive seen this one but seems a lot of money for a used one but its 100% correct for my car
http://www.ebay.co.uk/itm/2007812060...ht_3006wt_1344
