1997 E300D Oil Pan Gasket Help
Old Jul 22, 2012 | 12:18 AM
treiberg's Avatar
2003 C230 and 2005 C230
Looks like I have a leak from the oil pan gasket, but having trouble locating a thread that explains how to do it. Some threads reference that the WIS says you have to raise the engine (remove exhaust manifold, etc),which sounds pretty involved.
-Does anyone out there have a snippet from the WIS that would help explain how to do this?
-Is it necessary to raise the engine?
-Does anyone have experience with any products that can seal a pan leak from the outside. Supposedly there is some type of sealant that can be sprayed on externally to stop a pan leak.
Old Jul 23, 2012 | 01:56 AM
treiberg's Avatar
After cleaning and then re-examination, I do believe the leak is coming from something above the oil pan. The trouble is, I cannot see what it is. It looks to be something behind the starter or near the lower portion of the oil filter housing. It is really hard to see anything back in that far. Anyone know of any particular vulnerabilities for leaks in that area?
Old Jul 24, 2012 | 05:39 PM
treiberg's Avatar
The car is on ramps and I have good access to that area - however, I don't have easy acccess to that side of the block (where I see shiny new oil) because it is above or behind the starter. From the top, viewing is hard because of intake manifold.
Old Jul 24, 2012 | 09:13 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
You might find a mechanics mirror useful. They are inexpensive, small mirrors on a telescoping handle. Helps to see into nooks and crannies, etc.
Old Aug 13, 2012 | 02:17 AM
treiberg's Avatar
Finally found my problem, and it ended up being so simple.
The leak was coming from my oil filter cap - the last time I changed the oil, the replacement o-ring provided was not the correct size (it was too thin). I compared it to one from a new kit that I had, and it wasn't even close.
The key to an oil leak is to clean eveything up well enough to see the source of the leak. I was fooled into believing it was coming from oil pan, or from the base of the filter housing. These would have been much harder to repair!
Put the correct o-ring now, and am leak free again!
