1999 E300 No Crank No Start
I had problems with the shifter not going into gear from the previous owner who had to move the car after the battery died and forced the car into neutral to get it towed after a tree fell on the trunk. In order to shift the car I would have to manually move the shift linkage to get the car into gear.
The car would only start if I moved the shifter into neutral. Now that the shifter was taken apart and put back together it shifts fine, but I can't get the car to crank in any gear. I've checked all the fuses and everything is fine. Im thinking it has something to do with the shifter. Any ideas?
When jumping the starter directly it turns over, but the car does not start. Im gonna look at a wiring diagram and see if i can't trick the car into thinking its in neutral.
