2002 E320 Passenger Side Mirror not working
Old 09-03-2012, 09:37 AM
jojuseb's Avatar
2002 E320 Silver
The passenger side mirror tilts down on reverse but when back on drive, it does not return to normal position. Any know how to fix this? Do I have to replace the the entire mirror or any part? Please let me know. Thanks.
Old 09-03-2012, 10:30 AM
raymond g-'s Avatar
99 E320
if you can, pop off the cover and check for debris. you can also apply a little
pressure and manually move the mirror itself a little -- try to center it
Old 09-04-2012, 07:38 AM
jlee240's Avatar
e240 1999
Mine did this too. Just press the memory seat to adjust the seat an mirror. Switch off and restart car and mine normally goes back to auto dip and return to normal drivin position after about 18 seconds.
Not sure why the mirror does this but I thought mine was broken too. This seems to get it all back to normal again on mine
Old 09-10-2012, 06:11 AM
jojuseb's Avatar
2002 E320 Silver
Thanks to Roaymond G and jlee240, I will try the memory setitng first and if does not work, pop the cover to oil it may be - thanks again.
Quick Reply: 2002 E320 Passenger Side Mirror not working
