Comand Install - '98 E class HELP!
Old Jul 26, 2003 | 12:39 PM
justinj's Avatar
Question Comand Install - '98 E class HELP!
Hi
I have successfully installed the Comand into my '98 E class however, I did not have the speed sensor wire under the right hand door seal (black and green one).
Does anyone know if there is somewhere on the '98 E class I can pick this up from? maybe soldering something to the back of the dash or something?
I look forward to any help and advise.
Thanks!
Justin
Old Jul 27, 2003 | 12:51 AM
E-Klasse's Avatar
W205 C300
Help
Check out this site... Click Here
Or contact Steve "MBenzNL" for more info. s_krabbenborg@hotmail.com
He is the Comand expert...
"You need one wire for the speed sensor (position 6) The speed sensor is a green / black wire with a piece of black tape in the right door sill. Open right front door, remove plastic door sill and look for a unused wire. It usually has a blue connector on it. There's a LOT of wires, but you'll find it."
Old Jul 27, 2003 | 04:47 AM
justinj's Avatar
Exclamation
Thanks for the info, I did have this site address which I had found through this forum before fitting. I used this as a reference through the install.
The problem is (as I mentioned above) my car does not have the speed sensor wire. It must be because it is a '98 model which was not ment to have the nav system at all.
I am lead to beleive the infamous black and green wire comes form the front ABS sensor. IF so, I was hoping to pick it up from else where.
Thanks once again, I will keep the thingers crossed that someone out there knows!!
JJ
Old Jul 27, 2003 | 05:31 PM
E320's Avatar
tap it on A connector pin 1.
Old Jul 28, 2003 | 09:41 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
The car has a speed wire and it is already at the radio (as mentioned above)...loop A1 to C2 pos 6...
greetingz,
