AC Problem: cold air and warm air
I faced this problem when I used to have a leak, and the mechanic found out that the leak is coming from the compressor pressure valve. He replaced it or even solders it I don't remember. But also he changed the filter bottle and as far as i remember he changed the refrigerant temperature sensor which is found above the filter bottle.
Since that time on, there is no leak but i started to have this issue (blowing cold air then warm one).
For the error codes I have performed the test and i got the following:
EB1 227
EB1 231
EB1 232
EB1 234
EB1 235
After clearing those codes, only the EB-234 remains, so I've changed the sun sensor and after the clearing no errors appeared. But the problem is still there.
So I have decided to replace the external temperature sensor with the plug as i had intermittent connection with the plug. The same for the refrigerant pressure and temperature sensors on the filter bottle has been replaced as well. I recharged the system with the 134a but the problem remains.
I have the following note: when the external temperature sensor has been replaced I found out that the temperature showed on the dashboard is the same as on the diagnostic code #2 only the beginning when running the car but after a while, i found a lot of deviation. I mean when the dashboard shows 30 C the diagnostic code could show 39, or 42 which is higher than the actual. So I am wondering if the refrigerant temperature sensor is doing the same. So it could be it is giving high temperature reading to the control unit which makes it not working properly!!!!!!!!!!!
The following are the diagnostic codes just after running the car and the engine is idle(the car is not moving):
1. 30
2. 42
3. 06
4. 07
5. 02
6. 78
7. 13
8. 53
9. 00
10. 1.3
11. 4.3 (after a while it shows E)
12. 3.8
20. 2.0
21. 06
22. 00
23. 00
24. 13.1
40. 71
41. 34
42. 72
43. 152
Then I kept pressing on the gas pedal for a while, and the evaporator temperature on the diagnostic code #5 started to increase gradually and the pressure sensor code #7 started to decrease gradually.
Many Thanks
I think there is some thing fishy!!!!
could be the auxiliary fan is not working properly??? as it never worked on high speed!!!!
By the way, the mechanic is saying that the compressor is defected, is that possible???
