Front Passanger Spring/ Shock Noise
2000 Mercedes E320 Sedan
Around Front-Passanger spring/shock is starting to rust
is this a recall on this car?, or what do i need to do?"
98 Brilliant Silver E320 Wagon
Early W210 models had an issue with rust under the mastic coating of the front spring perch. If you have rust in that area I would have it inspected. I don't believe there was a recall. Also, there is/was a repair kit to weld in a new spring perch.
