Quick Radio\Ac control question.
try running some searches in the audio forum and you might find the thread.
someone had posted a pic on one of these threads awhile ago where it was done. They were installing a video screen/head unit and wanted it on the top. As I recall, the only issue was that some of the wiring had to be extended in order to make it fit; other than that, it was the exact same size and the depth wasn't too much of a problem.
The main issue is to make sure that the radio, when installed in the climate control space, is being adequately supported. In some models the support is intended only for the very light (and sub-DIN sized) climate control.
-s-
