1997 E320 Cylinder 4 Misfire
12/20/12 - My father took it to a mechanic last month(Car was idling very rough) mechanic said it needed an oxygen sensor, after that the car was good for about 2 weeks, and then the same malfunction that the mechanic was supposed to fix has returned(Cars idling rough).
I'm thinking its been a misfire all this time? Or did the mechanic incorrectly install the sensor? Or is the sensor not the problem? It's hard to determine if whether this is a coincidence or not
If no CEL then you have to be knowledgeable with MB to symptom diagnose the car.
The problem is that there are loads of faulty parts that manifest a miss-simple ones--plugs, wires and coils-----have you looked at the plug vs other cylinders--bla bla bla
